Type of engine oil using
  • Type of engine oil using
    What type of engine oil is the group using.
    Multi grade or w100
    Time to change for storage.
    Don't fly in the winter months any more.
    We are Snow Birds
    Robbie
    TF#832
    N44338
    "46" BC12D
    Fond du lac WI
    Re: Type of engine oil using
    I swear by Phillips X/C 20W-50. Used to use Shell, but changed a number of years ago and will never go back.
    Louie
      Louie
        I also use Phillips X/C 20/50 in both of my planes one is a 150 HP Franklin ain my C85-12 continental the trip to blakesburg was 1100 Mi the Franklin used a Qt and the c85 used very little
          Robbie, I've been using Phillips X/C 20-50 year round for a while now also. I just found it easier to fly whenever we got an earlier cold snap. Before that I used W100 in warm weather, and changed to Aeroshell 15-50 in winter. Getting a pair of skis made me decide I wanted to simplify the change over to cold weather flying as much as possible, and I didn't then have to think about the oil, just keep it changed as needed.
          On this last trip we took in September, I did decide to use Aeroshell 100W, just because I figured that would be easier to get at FBOs "on the road" to add a quart when needed, as well as for oil changes. Between the flight out to the Pacific NW and back to the Midwest, then down to the Fort Worth area to ferry the Chief with Rob and then bring him back, I put 82.5 hours on the Tcraft. The oil consumption was the same with the 100W in 50 - 90° temps as I would see with the 20-50, about 1 qt. in 12-15 hours.
          NC29624
          1940 BC65
            Exxon Elite 20W-50 but I am also a fan of Phillips XC 20W-50 as stated above.
            Oh, and Robbie, if you are leaving it for extended periods you should follow the Continental instructions for storage for that engine. Definitely a PITA to do but engines aren't cheap or easily obtained.
              Thanks for the input guys. Will try the Phillips. And one addition point is it cheaper than shell w100
              Robbie
              TF#832
              N44338
              "46" BC12D
              Fond du lac WI
                I used to deliver 55 gallon barrels of shell 100 to the DC3's that were flying tourists in the 1990's in anchorage, we ran out, so they took the Phillps, they were using 1 barrel for a change and 1 barrel in between oil changes with the Shell, they went to half of that consumption with the Phillips. Sold me on it. Tim
