On my BC12-D, there was a material on the brake pedals that I first thought was red mud but when removing it - material appeared to be old cured adhesive.
Question: Did brake pedal originally have a glued on rubber pad or have they always been bare metal?
with the preformance of my brakes, untill replacing the linnings , cleaning the shoes and adjust
. Now, I would not have it any other way. Over 140 hrs since change at last annual and still working fine at full throttle as of this day.
There is nothing wrong with Shinn brakes if the pedals were installed so you could use them when you had your feet on the rudder pedals like a champ evenon the side of the rudder pedal. Regards Marv
