Re: Wing leveling
Yes that's a possibility. Without a welding jig in which to do a repeatable repair, or blue prints to confirm dimensions, it's up to the repair folks to do the best they can. The dimensions I've seen apply primarily to longitudinal and not latitudinal tubing.
Now for the rest of the story that may confirm your experience...On 12/18/70 in Illinois repairs to the lower fuselage in the vicinity of the landing gear were accomplished and the airframe recovered. Log entries and a 337 indicate the right gear fittings, gear truss members, and lower fuselage tubing were either replaced or repaired with the inner sleeve method. It's very likely that the width of the fuselage slightly increased leading to a change in dihedral and potential range of washout.
I'm not concerned about the +0.5* dihedral, didn't retain the original struts for comparison, nor have I measured the new units. She flies fine and for being five years older than me (74) still gets the job done like a happy Taylorcraft despite the wounds and scars.
Originally posted by 3Dreaming
View Post
