Linseed oil stain
  • Linseed oil stain
    What in heck can you use to remove hardend Linseed oil stain from airframe, except a chisel, but I've about come to that point!
    46 BC-12D Taylorcraft
    46 Chief
    Re: Linseed oil stain
    Airframe is too general for me to say what to use.
    Some guesses are if it's on painted steel maybe try MEK/acetone/lacquer thinner.
    If it's on fabric try Oops! or Goo Gone or Goof Off.
    If I had that problem that's what I would start with.
    Dried linseed oil is similar to dried paint so a paint remover kind or product should work too.
      I get a little drip or two, after treating the struts, running down the lower edge of the plane. I believe I utilized lacquer thinner without any problem with my finish. Your mileage may vary depending upon covering/paint.
        A clothes iron covered with a piece of cotton, old cotton T shirt for example. Adding a little WD40 might also help. If on fabric keep the iron 225 degrees or less.
          Heat...thank you Scott, never thought of that.
          I've tried lacquer thinner, acetone, gun wash & few others, so far putty knife is only thing that worked!
          46 Chief
            Seeing the reference to treating struts, and having just performed the recurrent inspection (complete with teeth gnashing), it's likely I will be rewarded again with LPS3 dripping out the drain holes and blowing aft for nearly the next 4 years. Gunk engine degreaser has been my cleaner of choice.
            Mike V.
              GUNK!!!
              I have some of that & never thought to try it.
              46 Chief
                Try HOPPE'S BORE CLEANER. I used linseed oil on some rifle barrels that I put in storage, for six years. I tried every thing to get it off, and
                tried the bore cleaner. I soaked a rag , ran it up and down the barrel and it took the hardened linseed right off.
                Don Hanes
                  Don Hanes
