Shims for Control Column and Rudder Pedals
  • Shims for Control Column and Rudder Pedals
    Is there a commercial source for the brass shims for the rudder pedal and control column pivots? My A&P lost them when he sent the Control Column and Rudder Pedals out to be powder coated.
    Re: Shims for Control Column and Rudder Pedals
    Try this Link...
    http://www.mcmaster.com/#standard-shims/=x6171s
    CLICK on the "Brass Shim Stock" link. I think .005 inch is close to the correct size.
      REMEMBER TO PUT THE OIL HOLES IN THEM!!!!!!!!!
      I have seen several on planes with no oil holes. Makes a real mess when no oil is getting to the moving surface!
        I not only don't have the brass shims, I also don't have the clamps that hold down the rudder pedals or the control column. Does anyone have some of these clamps they can part with? I need the "singles" at the ends of the pedals, as well as the "doubles" in the center that hold them together.
        I also need the clamps that hold down the control column.
        Thanks.
