A65-9
    Re: A65-9
    Number one there is no such engine the A65-12 does not exist period.No A series engine other then the dash 9 had the option to put on a starter.Now the dash 8 engines of the C series also did not have a place for a starter either.The dash 12 and dash14 and 0200 had a pad for the starter,also there was no engine in the C series that was rated at 65 horse power.Drude i used a push button you have to drop the engine off the top mounts to get the starter off now the only one that will fit is a B&C so if that is what wicks is selling that is a good price my starter cost me $795.00
    Perhaps you should check the A-65 T.C.data sheet, It adresses the -12 model
      Re: A65-9
      this is all so informative thanks to all, I did check the Mooney Mite web site and there are several Mooney Mites with A65-12 engines installed , so I would say that it does exist.
        Re: A65-9
        Well sort of.
        Has anyone actually ever seen a Mooney Mite?
        Are we sure that they exist?
          Re: A65-9
          I have seen these engines and they are very similar to a C series. If you know what to look for, the cylinders are a dead give-away. They were only installed in the Deluxe models of the Mite, where I saw it. It's a pretty rare engine and not installed in many aircraft,so it's not too uncommon to find people that have not heard of them.
          EO
            Re: A65-9
            Unique aircraft.
            Unfortunately, there is an AD that is quite in depth re glue joints.
            Related to Culver & Dart as well.
            Had some dealings with these plus a 20A.
              Re: A65-9
              Unique aircraft.
                Re: A65-9
                All the parts should have part numbers, and a cross reference of which parts are common to A-65 and A-75 is in the parts manual.
                Best Regards,
                  Re: A65-9
                  Well sort of.
                  Yes, they exist. Over the last 50 years I've had the pleasure of flying several Mites. The one I flew the most, N476M, was powered by an A65-12. There is a list of Mites and the engines installed at: http://www.mooneymite.com/register.htm.
                  Garry
                    Re: A65-9
                    Garry,
                    I had not realized how few were made. Between 300 and 400 as I recall that list.
                    I have seen maybe two or three on the east coast since 1968.
                    Had not realized the glue joint AD's but it makes sense.
                      Re: A65-9
                      This may help clarification: http://www.luscombeassoc.org/tc/Cont...205,%20A65.pdf
                        Re: A65-9
                        This is what i thought they did
                        NOTE 8. Model A-65-12 differs from A-65-8 only in that C-75-12 type crankcase and accessories section are incorporated. they used a case from a C model to build it.
                          Re: A65-9
                          Isn't that a coincidence
                          a 65-12 on Barnstormers today!
                          With pics but didn't come thru
                          CONTINENTAL A65-12 • $8,500 • FOR SALE • 0.0 SMOH pickled in 1998, opened up in 2014. 2022.4 TTSN WITH LOG BOOKS. B&C key type starter with STC & 337. The generator, lifters, camshaft, cam gear, accy case, connecting rods, case, crankshaft, rocker arms and both mags (with new leads) all have yellow tags. What looks like new cylinders with new pistons, pins, rings and spark plugs. All new hardware throughout. Carb and carb heat/filter box can be included but have no paperwork. The wood Sensenich propeller is available separately. Looks like a brand new engine in and out. Going to something a little bigger. $8500/ make offer. • Contact Joe Boisselle, Owner - located Yakima, WA USA • Telephone: 509-728-0649 • Posted December 4, 2014 • Show all Ads posted by this Advertiser • Recommend This Ad to a Friend • Email Advertiser • Save to Watchlist • Report This Ad • View Larger Pictures
                          46 BC-12D Taylorcraft
                          46 Chief
                          • #28
                            Re: A65-9
                            Here you go.
                            • #29
                              Re: A65-9
                              Thanks for posting the data sheet
