Engine Failure
    Re: Engine Failure
    Originally posted by LostnSpace View Post
    DEPARTMENT OF TRANSPORTATION
    Federal Aviation Administration
    14 CFR Part 39 [Docket No. ; AD 47-13-02][R25H]
    Taylorcraft
    AD 47-13-02
    ATA Code: 28
    Recurring: 25H
    Airworthiness Directives; Taylorcraft Models BC-65, BCS-65, BC12-65, BCS12-65, BC12-D,
    BCS12-D, BCS12-D1 Aircraft.
    AGENCY:
    Federal Aviation Administration (FAA), DOT.
    ACTION:
    Final rule.
    47-13-02 TAYLORCRAFT:
    (Was
    Service Note 1
    of
    AD-696-3
    Applies to Models BC-65, BCS-65, BC12-65, BCS12-65, BC12-D, BCS12-D, BCS12-D1
    Aircraft.
    Inspection required
    each 25 hours of engine operation
    This inspection applies only to fuel hose bearing white dash lines and having end fittings
    marked “CAA, SNA (date)”
    It doesn't have this type hose or fittings, Tom
    How often have you seen these old birds with automotive type fuel hoses or unknown type hoses....... I deal with a lot of different aircraft and I bet I see more unapproved fuel lines then those approved, especially on older birds like taylorcraft, cubs, aeroncas, 120,140,140,150,170 etc. It's a good idea to replace any flex line in your main fuel supply line every 5 years or so. IMHO.
      Re: Engine Failure
      Originally posted by Mark Julicher View Post
      Sudden quiet was also the symptom of the stuck neoprene needle. Does anyone have one of this anymore??
      I have acutely had a steal needle stick on me. Developed a ridge at the mating point. Only the idle circuit worked if you advanced the throttle it would quit. The part that was bad was I was in the air at the time. Close to the airport so I made the runway. I would probably go threw the carb.
      Andrew Rozell
      N43697
      1946 BC12-D
        Re: Engine Failure
        ...with automotive type fuel hoses....
        To the best of my knowledge, Taylorcraft did use automotive fittings and hoses (why re-invent the wheel?). The changes are the recent aromatic fuels used.
          Re: Engine Failure
