Re: Priming the oil pump through the relief valve?
It should have a very small hole, moving oil through that small hole may cause excessive delay compressing air in the line.
However if within a few seconds after the oil pressure comes up at the initial start up we were to turn the engine off and notice how long after the prop stopped that it took the gauge reading to go to zero; then we would know how much delay is caused by the compression of air in the line.
