SS Tail Brace Wires
  • SS Tail Brace Wires
    Just a general announcement that after chasing my tail on this for a couple of years, I have finally found that we can get Stainless steel tailbrace wires as well as nipples and whatever those little half-cylinders are called from aviation supply stores.
    I got my SS wires from Wag-Aero because they were the only ones I could find that had the shorter 36.5" long wires that my airplane needs. 8-36 rolled threads. There was a little toe-tag on each wire that says:
    Aero Fabricators, Inc
    Lyons, WI 53148
    FAA-PMA
    Part No A-461
    Serial No: N/A
    Installation eligibility: BC-12D
    I also got the half-cylinders in Stainless Steel from Wag Aero. when I asked about the threaded nipples, the CS rep said that she could see them in their system. But she couldn't order them, even for back-order.
    But I was able to get the nipples in Stainless steel from Aircraft Spruce
    They came in little Ziploc bags that said the same thing
    The only difference was:
    Part No: A-986
    Eligibility: Taylorcraft BC-12D Nipple Tail Surface
    Aircraft Spruce told me that they only had 8 nipples in stock. And I ordered all 8. The ACS part number for the nipples is 05-05193. They have the #8-36 thread.
    When I got the parts, I hit the threads with Never-Seez and threaded them together. Beautiful fit.
    The straps I had made in Stainless at my local laser shop.
    Tim Hicks
    N96872
    Re: SS Tail Brace Wires
    Tim,
    I just ordered a set (8) of the A-986 rod ends from Wag Aero. I have not received them yet but my order showed 'shipped' last Friday. I had already decided to go with new stainless tail brace wires. While trying to remove the original rod ends three of them would not turn/come off of the rod. Glad there were replacements available not to mention in stainless.
    Greg House
    Brookshire, TX
    TF #1089
    BC12-D
    N96043
