Need OD of fuselage tube that goes across top from wing attach fitting to attach fit
  • Need OD of fuselage tube that goes across top from wing attach fitting to attach fit
    Found an Atlee Dodge clamp for a super cub to attach shoulder harness, if the tube is the correct OD it would allow the use of inertial shoulder harness with no welding. Thanks
    Fred Johnson
    N44467
    N96662
    TF#97
    Re: Need OD of fuselage tube that goes across top from wing attach fitting to attach
    Just wrap the shoulder harness around the tube, that is what many of us have done. Make sure it mounts higher than your shoulders so it does not compress the spine if there is an accident.
      I made my clamps out of 1/8 in 4130 sheet cut 1 in wide strip wrapped it around the spar carry threw and bolted the belts to it.My belts had metal ends with 3/8 in holes .
        My fuselage is uncovered and in my garage right now. So I can measure the tube for you.
        But I won't be back there until this afternoon.
        Just to be sure, check the photos below and verify that I'm thinking of the same tube that you're thinking of.
        Tim Hicks
        N96872
          Tim,
          That is the correct tube. Thanks
          Fred Johnson
          N44467
          N96662
          TF#97
            On my 1946 BC12D that tube measured 0.881". So that would make it 7/8".
              One thing with Inertia shoulder harnesses, you have to have the mechanism in a specific position for them to work correctly, if your metal strap can rotate, they intertia mechanism may not work correctly if it becomes out of position in a crash. Tim
                My airplane also is a '46 BC12-D.
                So I guess that it's no surprise that I also measured about 0.880" OD on that tube.
                Tim Hicks
                N96872
                  Richard and Tim, thank you, I'm in Alaska and one of the parts houses has one I can measure. I will try to post a picture and the results later in the week.
                  Fred Johnson
                  N44467
                  N96662
                  TF#97
                    Reeves or Stoddards? You might check out Chance Aviation and Tamarak if you are in Fairbanks. Tim
                      Bill at Stoddards, he has one in used in the back room, we can measure the tube on the Super cub fuselage, I think it is 3/4 tube it is designed to bolt around. McFarlane has a picture in their catalog, under Atlee stuff. Thanks to the tribe As always for the help.
                      Fred Johnson
                      N44467
                      N96662
                      TF#97
                        Here are some photos of the one i made as a owner produced part and installed with a log book entry.The FAA's position is any thing that is better then what these old air planes had and is ok with them.
