Kinda scary in the gusty cross winds.
Soloed today
Re: Soloed today
I've got a new found respect for you guys and gals that fly t-crafts in the "bush." Spot landing, that's damn near impossible. A cool fall day with zero wind, but final is over a highway and when everything is perfect a thermal from the road catches you and now you're 100 ft higher than intended. Nose down and you're now @ 70 over the numbers. I've got a lot of learning to do.Dave
F22 Experimental Build
46 BC12-D
N95078
Re: Soloed today
Originally posted by Nefj40 View PostI've got a new found respect for you guys and gals that fly t-crafts in the "bush." Spot landing, that's damn near impossible. A cool fall day with zero wind, but final is over a highway and when everything is perfect a thermal from the road catches you and now you're 100 ft higher than intended. Nose down and you're now @ 70 over the numbers. I've got a lot of learning to do.
Re: Soloed today
Dave,
I am sure you have heard that your license is only a license to learn. You are smart to not do anything in your plane you are uncomfortable with. Try going up to an altitude you are comfortable with and practice side slips. You can find a long section of straight road to use as an imaginary runway. I am sure your instructor showed you how to slip, so just go up and practice what you were taught. You will have to hold it for several seconds before it will become apparent whether or not you are staying aligned with the road. I am sure that if you spend a few minutes each flight practicing, you will feel comfortable slipping your way down closer to a runway. Even then, it is important to stay within your comfort zone. And always remember, the go around is your friend. That is another maneuver that should be practiced. Try it while you are at altitude over the road practicing your slips. It is not as easy as you might imagine, especially if you are trimmed down to a low airspeed.Richard Pearson
Re: Soloed today
Originally posted by Nefj40 View PostI'm not super comfortable using slips when I'm by myself yet. I have played with them at altitude, just not when I'm close to the ground.
Re: Soloed today
Thanks for the advice, and I really do appreciate it. There is a night and day difference between a Cessna 150 and a Taylorcraft. It's like relearning to fly all over again. I was more confident at 10 hours in a 150 twenty years ago than I am at 30 in a T-craft today. Maybe it's just wisdom (or caution) that's came with age.Dave
46 BC12-D
N95078
Re: Soloed today
Dave,
The trick is to get behind the power curve so that the throttle controls altitude and the yoke controls airspeed. Go up to a comfortable altitude and slow down to about 5 - 10 mph above stall speed. If you are holding a constant altitude, you will probably see a power setting about 15 to 20% below a normal cruise setting. But if you slow down even more, you will need even more power. Vary your airspeed down to just 4 - 5 mph above stall, while maintaining altitude. Notice the amount of power it now takes to fly even slower than before. While you are holding altitude and airspeed about 5 mph above stall - pull the power back 200 rpm and maintain AIRSPEED now. You will be starting down in a nice gradual descent, just above stall speed. If you want to increase the descent rate, do not reduce back pressure on the yoke. Instead, decrease the RPM just slightly. You are now using the throttle for altitude control and the yoke for airspeed control. Once you practice it a little, you will be a lot more comfortable on short final allowing the airspeed to reduce closer to stall speed as you approach the runway. Just don't let it get too slow and drop you in like a rock. If you enter the flare 5 - 10 mph above stall, it is a nice coordinated pull on the yoke as you pull the throttle off. Once you get it, there is no better feeling. Just make sure you are proficient at altitude before you try it down low. You ease into it as your skill level increases. My personal technique is to not trim below 60 mph. That way the force in my left hand on the yoke, gives me an idea of where I am as far as airspeed. I practice my stalls the same way. I know the amount of force when I am at stall speed and can compare it to the feel as I enter the flare. If I have to go around, I am already trimmed to my best angle of climb speed, 60mph for my plane.Richard Pearson
