Wanted to cut out on landing
    Re: Wanted to cut out on landing
    Does sound like your idle mixture is off for some reason. Carb blockage is a possibility as suggested but don't rule out a leaky primer as mentioned or a vacume leak in the intake.
    David
      Have not had the greatest weather for a few days. Trying to clear up but still MVFR for low clouds. Hope it clears some this afternoon. My air filter was changed in May , but have been thinking maybe it has something to do with it, definitely one of the most simple things to check out.
      Patrick Dixon
      1946 Taylorcraft BC-12D NC43328
        Unless you fly through a lot of dirt and bugs I wouldn't think so. Just to keep in-mind, when my engine cut out I could advance the throttle, and once it got out of the idle circuit, it ran fine, (basically because the engine wasn't pulling fuel through the little hole that was clogged). I carried power until I was well over the runway and pulled it back, where it quit. If it does this don't let the engine get too slow or it will not keep running no matter where the throttle is at. The first time it happened I did not realize it until I heard the impulse clacking. You can actually feel the the carb going from high range to the low range, even when it is running fine. You really know it when that port is plugged.
          Ok, I got to do a little flying. Air filter helped! I had noticed a little hard to stay running at idle when I propped it, would die before I could get in the seat. I just attributed it to the air getting cooler. Today, I propped it , it kept running and gave me time to enter the airplane . Did fine on take offs,...did a lot better on landings. It did not start to cut out,...but something just tells me it could run better if rpm was upped alittle. 500 is where it is, thinking maybe 550 would run a bit better ? In flight I ran it at 1000 and 750 and a few other areas of low rpms and it seemed to be fine with not even a hint of wanting to cut out on me.
          Patrick Dixon
            The filter wouldn't help your problem on landing. When landing you have carb heat on and the filter is not being used.
              Good point! Before I took her flying, I let her idle at different rpms on the ground. At 500 , she seemed to just not be running to peppy ( hard to describe it), at 550, improved( like an OK I am ready!), 600 same and on up to 1700 rpm's. Once on the ground I gave it throttle to about 1500 from idle and she stumbled a bit,...but only the one time. I did that about 10 times as I didn't like the stumble,..and sure was not going to fly her if I thought she was going to do that on climb. She only did it that one time on the ground, and she preformed nicely on climb out. When coming back in for landing, I did not get the clack of the impulse,...engine was running , just not great at idle. Wife is printing off a carb manual at work today, and I plan on taking the cowls off Sunday and checking the intakes and carb seat to make sure I don't have any air leaks there. If I find nothing there ,...befuddling! LOL RPM at idle to low? All the way out I am idle at 500. Since the air filter helped ....mixture?
              Patrick Dixon
                Try opening the idle mixture needle valve one half turn,See if that helps.500 rpm at idle is good.
                  Mike, I do believe that is the road to go down. Going to take the cowlings off and really check intake and such for signs of air leaks. If that all looks good then adjusting the idle mixture a tad.
                  Patrick Dixon
                    Had same problem where it would quit on landing roll out. Replaced all the O rings in primer and it helped.
                    Dennis McGuire
                      Well guys,
                      Had an IA at the airport take a look see. I adjusted it a tad and really never got it running "right" . IA says I can adjust till doomsday and it may run fine one flight and be off the next. Starting to get weepy around some of the gaskets, so letting some fuel out , some air in. He recommends I trade mine in for a rebuilt one or have mine sent off and rebuilt, as I would get a warranty for a carb shop. Being President of "The Poor Guys That Have An Airplane Club", what should I expect to have to spend? Will I have to sell one of the children? LOL IA says he would be glad to supervise the taking the carb off and putting one back on.
                      Patrick Dixon
                        I had these guys do mine and were reasonably priced. Link: http://kpsairmotive.com/
                        I cannot remember how much I paid, at the moment.
                        • #27
                          Originally posted by paddydix View Post
                          Well guys,
                          Patrick,
                          Rebuilding the carburetor seems a bit like a knee jerk reaction to me. That may fix your problem, if the problem is with the carburetor. But as someone else suggested, it could be a leaky primer. It could also be leaking intake tubes, sticking valves, or any of several other possibilities. I would certainly not rebuild a carburetor just because there was a little fuel stain around the gaskets. Someone with the mechanical skills can tighten up the screws, or even replace the gaskets. While they have it apart you can have them check the float level and the functionality of the needle and seat.
                          When troubleshooting problems associated with the carburetor I have found it best to find the answers to two basic questions. First, is an adequate fuel supply reaching the carburetor. Second, is the engine running too rich or too lean?
                          Please note - I AM NOT A CERTIFIED A&P MECHANIC.
                          Before you pay someone to rebuild your carburetor, this is what I would do if my plane had your symptoms. I would take Dennis' advice and eliminate the primer leaking as a possibility. Either remove the line and block it off, or replace the O rings. Then I would tighten up all the clamps on the intake tubes. I would also remove the fuel line at the carburetor, turn the fuel on and see if you have a good clean steady flow into a bucket. Even if you do, you may want to take the gascolator apart and clean the screen at the top. If all of that looks good, I would have a mechanic knowledgeable on your model of carburetor split it open to check the float level and working of the needle and seat. The reason I suggested in an earlier post to have someone watch for smoke while you fly the pattern was to answer the question of is it running rich or lean.
                          That is what I would do. Maybe some of the older heads on here will chime in soon with some other ideas. I can tell you from experience when trouble shooting many other engine problems; don't jump on the first thing that comes to mind, and always look for the simplest solution.
                          • #28
                            Before you have someone crack the carb open, make sure they know what they are doing. These little Strombergs are simple, but require knowledge on how to set-up float level, plus they take a little special tool to work on the seat level. Oh, and a lot of patience.
                            The other stuff is good, too. Make sure there are no air leaks, or excess fuel from the primer line, easier stuff to do than take the carb apart.
                            Even though I am now positive I had a piece of junk in the carb, I still replaced all of the intake rubbers, cleaned the gascolator, (definitely stuff in there), replaced intake elbow gaskets as well as carb gaskets. All fairly cheap, but time consuming to do. Have an A&P who is willing to check your work, not necessarily look over your shoulder paying hourly wages while doing so.
                            • #29
                              I have checked about everything I can check, and appreciate all the things to look for that I got from the forum members. It's been about 2 weeks of chasing things down on her, so not to much of a knee jerk for myself. I have done cargo door mods on Boeings in less time . LOL Myself I have worked under someone's ticket for 30 years so I am in the I don't have the A&P dilemma myself. There is only one A&P at the field,...the aforementioned IA. So a bit at his mercy. He is a good guy. With a bad flu I can still smell gas in the engine compartment, and though I hate to admit he is right and it isn't something simple,...I have to agree with his "take" on the carb. It is weeping pretty well,...not pouring but enough to cause problems. As for myself just changing gaskets,...refer back to the I don't have the A&P. The IA says if he does it, it would be just as cheap to send it to a carb shop and have a warranty. I do agree Marty, find someone who really knows them!
                              Patrick Dixon
                              • #30
                                I have read a lot of info from The Stromberg guy online,...he seems to really know them,...he is a bit pricey though.
                                Patrick Dixon
