Bungee tool locations and regional Taylorcraft tribes
  • #31
    Re: Bungee tool locations and regional Taylorcraft tribes
    FYI Guys,
    Wag-Aero is advertising the T-Craft installation tool for $172.50. Catalog # M-942-000. (Catalog dated March 2013. I have one of Ferris' in Mooresville, Indiana (near Indianapolis. I will install yours but will not loan the tool).
    Mike A&P/IA
    • #32
      I have a jackscrew tool in Peru Maine
      • #33
        I have an original Taylorcraft bungee tool in Bulverde, Texas
        • #34
          I think the problem with not seeing the map is that the program is trying to display above the North Pole. You can try dragging the map upwards or try this technique:
          Open the menu "View" and select "Search". Type in wood click search hopefully the map appears. Again, open "View" and now select "refresh"
          I think that having markers on multiple continents, the display is a wide but short map. And the landmasses are below the viewport. Bottom line, it's Robert's fault. That's my story and I'm sticking to it.
          I have deleted Robert's marker for now to see if that helps. Anyone that has had problems, please try again and let me know results. Robert, I will put you back on the map in a day or so.
          Mike Wood
          Montgomery, TX
          '46 BC12D
          N44085 #9885
          • #35
            Hey Mike,
            I just kept dragging up and found it. My locations isn't on there but at least I can see the map now. Sort of...
            • #36
              I just added the latest 5 entries to the map. There are 19 markers. Robert is not included for now, but will be back soon. In the upper right, just off the map, is a small box with 'double arrows', <<. Click this box to display list of markers.
              Mike Wood
              Montgomery, TX
              '46 BC12D
              N44085 #9885
              • #37
                I have one up here in northern Wisconsin. Might make a nice trip to deliver and make T-talk.
                • #38
                  I have one on the west side of Kentucky, Shelbyville,40KY is our airport ID.
                  Fred Johnson
                  N44467
                  N96662
                  TF#97
                  • #39
                    The scale at the lower left of the map shows a One Meter resolution, the map is blank and the latitude and longitude is unknown. Perhaps if the scale were somehow defaulted to 100 miles then I could figure out where on earth the map is showing. Otherwise, I see a blank map.
                    • #40
                      I have one here in Butte, Montana.
                      Charles
                      • #41
                        I have near Fischer Texas
                        Buell Powell TF#476
                        1941 BC12-65 NC29748
                        1946 Fairchild 24 NC81330
                        • #42
                          Hooray!
                          It now seems to be working for me:
                          • #43
                            I have a bungee tool in Poplar Grove,Il
                            Craig Bailey
                            847-302-0017
                            • #44
                              It's working for me just fine, I looked at Califormia and Oregon, that is a surprise that none show up "out there", gary
                              • #45
                                For those still having trouble, click on the small box in the upper right corner with the double arrows, <<, to display the list of entries. Click an entry. This should move the map to show the selected marker. You can then resize using the +/- zoom control.
                                I have tested on desktop, laptop, netbook, ipad, iphone. Windows XP, Windows 8, latest ipad/iphone. All seem to have their quirks, but all work.
                                For some unknown reason, to me at least, the display has the actual map below the screen, if that makes sense. As Marty reported, you can drag the screen up a number of times, 3-4 worked for me, and finally see the map. Drag the USA to the center of the screen and zoom in. When you return to the map at a later time, it seems to remember your last view, so it must be setting cookies in the browser.
                                I will add the latest reported locations Friday.
                                Mike Wood
                                Montgomery, TX
                                '46 BC12D
                                N44085 #9885
