F-21 8.50x6 tires?
  • F-21 8.50x6 tires?
    hello all ,
    New to the site and seems like there is a lot
    Information hear. Does any one have info. on using
    8.50 x 6 tires on an F-21? Must not be to many of us
    with 21s out hear. Also any O-320 mods for a F-21?
    Need more power and prop. clearance.
    Thanks,.... :hammer:
    Re: F-21 8.50x6 tires?
    Go with AK Bush wheel 26 or 29 in tires will give you prop clearance.
      What the *%$#? I like the way you think! We won't be
      Landing on any river or big ass rocks yet! 8.50s should
      work for now. Going with O-320 w/ an 80 or 82 inch prop.
        the type cert for b model shows a 83 in prop the prop in this photo is 74 in an 82 in is 4 in more on a side and 26 in bush wheels are not much taller then 8/50 tires
          Hey!! Finally someone else who likes the idea of a Super Taylorcraft. I have a 46 BC12D with the 0320 lyc 160 hp. I didnt like the noise and vibration of the 82 inch borer so I had Craig Catto build me a 76 by 44 composite 3 blade and I would never go back . It is smoother quieter and 12 lb lighter. Phenomenol initial thrust and great climb performance. I had 850 by 6 rubber but switched to 21 by eight tundra tires. lighter . cheaper and 4 p[ly sidewall. only slightly larger than the 850"s and fit on the same wheel . If you are going to put the heavier engine youwill want to upgrade to the heavy alaska airframes struts. along with many other mods. Drop me an email if you want more info on my conversion. [email protected]
