Flying S. Texas
  • Flying S. Texas
    On 24th July Doc and I set out to circumnavigate South Texas. Route of flight was from Bulverde, Texas to Eagle Pass, Zapata, Port Isabell, Port Aransas, and return. Total distance was about 700 nm.
    Here are some things we saw along the way.
    Uvalde, Texas was out first checkpoint and as you can see, the weather was dicey. Actually, we started out together at 2000 feet with 10 miles visibility and Doc in the lead. When we encountered a thick cloud bank, Doc went VFR on top and I went under... so much for flying together on that leg. Doc had radio problems, so we had no idea where each other happened to be. So I text-messaged position reports along the way and we eventually got hooked up at the first planned fuel stop.
    Near Uvalde is a rather nice and very exclusive hunting lodge. What is known as a "nice spread."
    A bit farther along, just southwest of Del Rio is a GM test track. I have no idea if it is still in use, but when I was a USAF student pilot in 1973 it was active.
    Not far from the test track is a ranch with two large grass airstrips. I have no idea what the rancher flies in and out of there.
    Approaching the Mexican border at Eagle Pass, Texas I was low on fuel. the winds were not favorable and we had dodged a lot of clouds early on, so I stopped at this sleepy old WWII training site and got gas. Doc passed overhead and turned South for Zapata. From Eagle Pass to Port Isabell we would parallel the border and were very mindful the hazards - There are aerostat sites with 12000 foot cables are all along the border. The sparse population meant nobody was going to find you quickly if you had to land out. We carried water and a snake exterminator in each plane.
    At Zapata we refueled. Doc, with 24 gallon capacity had his first fuel stop. The sign over the Zapata airfield entrance says "Home of the World Record Encampment" I had no idea what that meant at the time. I envisioned a humongous camp out with people as far as you could see. Not so. It turns out that since 2000, hang glider enthusiasts come from all over the world to Zapata to ride the tremendous lift and set distance records. Cumulous forms before dawn and by the time the desert heats up there are streets of lift for hundreds of miles. Hang gliding for hundreds of miles YOWZA! Impressive.
    We navigated our way past the next aerostat site and approached Harlingen. This part of Texas is subtropical. Much of your citrus fruit comes from here. Yes, Florida and California are better known citrus producers. At any rate, there had been a LOT of rain on Texas early this summer and the Rio Grande was pretty darn full. So full in fact that the levee around Harlingen was in full flood. I had to check the chart several times to be sure I had not wandered too far South, but no, just a levee on the north side of Harlingen.
    Finally we skirted Harlingen and saw Port Isabell. Gateway airport to South Padre Island and all the hotels etc. Post Isabell was to be another gas and go.
    Best Regards,
    Re: Flying S. Texas
    Last episode, Doc an I were about to land at Port Isabell.
    But first, here is a photo of what was Laredo Air Force Base Auxiliary field one. The runway and taxiway are visible, but on close inspection the concrete has been pulverized into large chunks - totally useless. Back in 1973 this was very active. Call sign of the field was "Barfly" and T-38s used it every day. Then Laredo AFB closed and the aux field is history.
    So here we are at Port Isabell. I don't know which hurricane blew out the glass in the old control tower, but it is in severe disuse now.
    I don't know the story behind this A-4 tail, but it appears that it would not fit in the dumpster.
    We took off after taking on fuel and here we are climbing out next to Laguna Madre. Yep, it is the Mother Lake, huge, warm, and shallow. East is Padre Island, West is a lot of nearly uninhabited South Texas.
    A short time going North up Laguna Madre and here is a water front house with a grass runway. Dude, get a sea plane! You could land long and wind up in the living room.
    A bit further north and here is a fishing camp. I figure there isn't enough mosquito repellent in all of Texas for me to want to fish there. But hey, where the fish are biting, someone has to go catch them I guess.
    Best Regards,
      Re: Flying S. Texas
      Last installment for this travelogue...
      Doc and I are flying our intrepid Taylorcrafts, (I did not say I was intrepid, my plane just does not know any better), wending our way north along Padre Island National Seashore. South Padre is SAND and more SAND, but as we get further north is becomes greener. Don't think for a minute that is is hospitable, insects and other critters rule out here. Back in the day, no, even before that, the native tribes on these islands slept with a circle of smoke fires around them to keep away the insects.
      Well the first picture shows the inter-coastal waterway, Laguna Madre, and Padre Island.
      Next photo are some fishermen on the coast of North Padre - looks like they plan to be there for a good while.
      As we approached Corpus Christi we had to go East to stay out of Class C and D airspace. Radios were just for actual traffic pattern and landing. No need to spend battery talking to controllers. So here is Doc with me in chase out over the middle of Padre Island.
      Corpus Christi is mostly on the mainland, but a drive over a long causeway and you are out on the North tip of Padre island.
      Doc and I are about to violate my number two rule for safe flight -"Don't fly over more water than you can drink." But we have to get to Mustang Island and then Port Aransas for fuel.
      We made it over to Mustang - and look at the hot people cooling off at the beach!! It is legal to drive on most Texas beaches. It is also legal to get stuck in the sand and pay a lot of money to be towed out. I'm just warning you.
      Well, we got fuel at Port Aransas. We were tired. so we flew direct to Bulverde and called it a day. About 9 hours flight time was enough for the day. Now we are thinking about circumnavigating West Texas. Hmmmm. Big Bend, El Paso, Salt Flats, Guadeloupe Peak. Midland Odessa.
      Best Regards,
        Re: Flying S. Texas
        Hey-Just about to go to work and read this about you and Doc on another adventure over some of my old stomping grounds. I used to like to fly to Victoria @ Down the coast to Corpus @ land @ Robstown to visit my sister who lived there. I picked up the J-3 I am working on from a crop dusting strip just out of Uvalde. The hill country to Uvalde sure is beautiful rugged old county to fly over. Did you see the Lexington off South Beach? Well-back to work and now thinking about flying somewhere.
        Thanks for the pictures--Doc's T/Craft really looks classey.
        Buell
        Buell Powell TF#476
        1941 BC12-65 NC29748
        1946 Fairchild 24 NC81330
          Re: Flying S. Texas
          Great pictures of S. Texas- I've been to all those places, but only on the ground. Neat to see it from the air! It took a lifetime of traveling to see all that by car, and you did it in one day!
          West Texas Loop sounds like fun! Think Pena Bird can make it?
          Mike Rice
          Aerolearn
          BC12D N95910 Tale Dragon
          TF #855
            Re: Flying S. Texas
            Mark,
            Very nice, thanks! :bravo:
            NC29624
            1940 BC65
