NEED rear spar fitting at Fuselage (RH)
  • NEED rear spar fitting at Fuselage (RH)
    I don't know if R and L are different, but I need to replace the aft spar fitting. Does anyone have an extra available.
    I will post more about the reason later, but I have the RH wing off of N95598 right now and just removed the wing tank... yep I am in for some fabric work too.
    Re: NEED rear spar fitting at Fuselage (RH)
    they are interchangeable, do you need for post war with the u bracket welded in? I will look, should have one
      Mike... I appreciate it but no thanks... I found one and its on the way.. Thanks to AJ and others for quick response.
