Need Help with Gear upgrade.
  • Need Help with Gear upgrade.
    I am wondering if there is any 337's or some type of approval,STC,factory approval or something I can use as previously approved data to upgrade the landing gear on Crispy(1946 BC12D) to F19 gear legs with the mechanical cleveland brakes? Any type of help would be very helpful.
    Re: Need Help with Gear upgrade.
    I know of 2 airplanes that did it in Alaska, I can find out what they used for data, I just made bushings for mine to convert to hydraulic brakes. Tim
      It would be great if you could find out what/if approval they used along with a copy.
      Thanks
        I will call and ask, you might have to buy one of the cd's for which ever airplane. Tim
          Not a problem but I don't want to do that without the owners permission to do so. Thanks Tim.
            You dont need the owners permission, its open under the freedom of information act. You just order the cd. then use the info as supporting data..Tim
              You are correct,but I do need the N# for the airplane and out of respect for the owner and his bird I would rather have his blessing. It would just make me feel better about it.
