I'm looking for wheel pant mounting hardware for Crispy Critter. I need backing plates and axle nuts? If anyone has them for sell please let me know.
Thanks
ACS sells the cowl grills as well as a few other folks out there. As for the axle nut there are a couple different ways I've seen it done but the nut is the best. I know Wag Aero sells the backing hardware for the pants but I was just hopeing I could find somethine used for less then $100.
I got brackets but they are just too used up to be anything but a pattern. Different from a standard AN nut? yes. it is a hex bar turned into a nut made both from steel and aluminum.
I had a friend turn some nuts for me last week. I gave him a bar of 4130 and a sketch. They are 1.60" long with 3/4-16 threads half way through on one end and 1/4-28 threads on the other end. A hole is drilled in the 3/4-16 end for the cotter pin.
