BC12-D Center Aileron Brackets N.O.S.
  • BC12-D Center Aileron Brackets N.O.S.
    I have a few new old stock center aileron brackets/ hinges for sale. I also have the bellcranks but not the shaft etc. Let me know if you need one. Best to reach me by phone. These are the ones that are usually found cracked when you re-build due to corosion. $50 for a bellcrank and bracket plus shipping.
    Eric Minnis
    336-227-8941 home
    336-662-1029 work
    Eric Minnis
    www.bullyaero.com
    Clipwing Tcraft x3
    Re: BC12-D Center Aileron Brackets N.O.S.
    Left or right? (I don't need them...just enquiring).
      Rob- Good to hear from you! I should have specified. . . . I have only the left side for now..
      Eric Minnis
      www.bullyaero.com
      Clipwing Tcraft x3
        Eric Minnis
        336-227-8941 home
        336-662-1029 work
        eric do you have any prewar jury struts and good rear struts for prewar. tom bakertf#25
          Tom- I do not have much pre war stuff at all but I will keep an eye out. The jury struts are really easy to make though.
          Also- I stand corrected on my hinges- I only have the left hand side hinges. I know there are more where I got these so I will go look for r/s hinges this weekend.
          Eric
          Eric Minnis
          www.bullyaero.com
          Clipwing Tcraft x3
            Eric,
            Do you have or know where to get a pair of BC12D Landing gears?
            How about a left wing? No cover needed.
            Larry Wheelock N96179
            lawheelock@earthlink.net
            Terre Haute, IN
            812 877 1730
            Eric Minnis
            336-227-8941 home
            336-662-1029 work
              Larry- I have a set of wings that may be available. I want to make sure I have enough spare parts on mine before I get rid of them though- plus a local friend has first chance at them. Anyway- if I decide to sell them I will let you know. I would want to sell them as a set just to keep them together. The steel parts look really good but some of the ribs have some corrosion where the martin wires (dissimilar corrosion) interface. AS for the gear I do not have an extra set but will keep an eye out.
              Take care.
              Eric
              Eric Minnis
              www.bullyaero.com
              Clipwing Tcraft x3
