I have a tg6 converted to l2 but do not have wings. My question is will bc wings fit or can they be made to work with strut modifications? I am in the process of making wings but have no hardware. I have been able to get an origional rib and have made all my wood ribs. I have access to spruce for spars which will have to be laminated lengthwise as they are narrow strips left over from an aeronca spar builder.Where are wing blueprints available? I have the cd set for l2. I am going to go experimental so exact duplication is not a factor. Thanks, Jim Tate
wing interchange
Re: wing interchange
Nope, will not work or made to work. Nothing is the same from brackets to aileron control system. I have plenty of wing hardware if you are in need of it.Originally posted by jimmel View PostI have a tg6 converted to l2 but do not have wings. My question is will bc wings fit or can they be made to work with strut modifications? I am in the process of making wings but have no hardware. I have been able to get an origional rib and have made all my wood ribs. I have access to spruce for spars which will have to be laminated lengthwise as they are narrow strips left over from an aeronca spar builder.Where are wing blueprints available? I have the cd set for l2. I am going to go experimental so exact duplication is not a factor. Thanks, Jim Tate
All I have is a bare airframe with tailfeathers, gear ,and struts. I was going to make the wings and have all the ribs made but do not have any hardware. I thought I had a set of wings located that needed a complete rebuild(that is why I built the ribs) but that deal fell through. I suppose I could take a pic of airframe if you would like. Thanks Jim Tate
