bungee cords
  • bungee cords
    I am about to replace another set of bungee cords on my L-2. The last set only lasted two years. I was looking at aircraft spruce and they show a set for l-2's and D series. They are two different sizes. The l-2 is 3/4" longer...
    Anyone know why? I would like to get a set of stiffer bungee cords, what are YOU using in your L-2?
    -Jay
    Jay Stanford
    St. Marys GA
    1942 L-2B
    Re: bungee cords
    If your serial number is 4200 or higher you should use 11104. Your landing gear front tubes should be 1.5 inches in diameter.
    TF #10
      Re: bungee cords
      That is the deal with the tube sizes. My SN is 4137, but that is just on the throttle handle who know what the gear is.
      Thanks again.
      Jay Stanford
      St. Marys GA
      1942 L-2B
        Re: bungee cords
        Exactly , you have to check the shock struts that are on YOUR airplane. There has been a lot of changing around out there. The choices are 1192 & 11104 , then we have the few and the brave that use the 1110 or a combination. I have pictures on the the other computer. Must bring them tot he house someday. I have three calls into Superior ( SBC) ; probably fouled that up I mentioned Taylorcraft......:hammer:
          Re: bungee cords
          I'm running 11104's on my L-2M and there is no suspension whatsoever on the plane -- i.e. the bungees are so tight that there is zero movement. The gear struts are correct for my plane and have the correct amount of travel -- 5.5 inches, IIRC.
            Re: bungee cords
            With the ship empty and new cords you can rock it abck and forth and the gear will not spread ( or even move) . Give it time, lower pressure in tires.
              Re: bungee cords
              My L2M is Ser#5224
              I hope to put it on the gear in the next 2 months.
              It sounds like I order 4 11104's. correct?
              Where is the best place to get them?
              Do you install with the same tool as a BC12D?
              If not, what is the procedure?
              Thanks Greg Guy
              Greg Guy 503-851-9595
              1945 BC12-D NC39258 #6412
              TF#29
                Re: bungee cords
                Greg,
                Take a look at an earlier thread here
                Ron Greene
                TF#360
