I am looking for the butt ribs that mount on the fuselage for a L2M. These are the ribs that mount on the fuselage not the butt ribs in the wings. Any help would be greatly appreciated. Thank you. JON MARTIN 610-476-1702
L2M Fuselage butt ribs needed
Re: L2M Fuselage butt ribs needed
Thanks Marty. Good to hear from you. There doesn't seem to be much activity here regarding L2 "stuff".Originally posted by M Towsley View PostHey Jon,
Hope things are going well. Good luck with your search, hopefully someone will pop-up with what you need.
No, not a lot. Not many l-2 owners. Couple guys are, though, but not sure if they still have stuff. Mike Redpath is one. Try on the Facebook page for T-Craft as well as the Antique Aircraft Parts page on FB.Cheers,
edit: mis read post. Those are the same as a prewar b rib minus the diagonal braces. I should have something here that will workLast edited by Ragwing nut; 12-24-2017, 13:36.
