Are they set by fell or , they set to 20 lbs.
Where do I find how tight to make all the control cables for BC12D-85
Re: Where do I find how tight to make all the control cables for BC12D-85
Jerry,
I checked the Taylorcraft Service Manual & Owner's Manual. Neither of them give any specification to adjust the cable tension. AC 43.13 says to use the manufacturer's specifications. But that is hard to do with a Taylorcraft when there is no factory. From what I have heard, the tendancy is to over tighten control cables most of the time. I know the aileron cables in my plane look loose, but they never seem to slip on the pulleys, so they must be tight enough. Maybe one of the I/A guys will chime in with info on the technique they use.Richard Pearson
Do a search on aileron adjustment. Forrest, a few years ago said to make the tension so they drooped about a 1/4" at rest. They would be in perfect alignment while in flight but no so tight as to add force required to move. Another words not very tight.
Larry"I'm from the FAA and we're not happy, until your not happy."
