I have a BC12-D w/an A65. Could someone please tell me where to place the markings (red, yellow and green) on the Air Speed, RPM, engine temp, and oil pressure gauges. I could not find a reference on the forum.Thanks a lot. Dick
Instrument Markings
Re: Instrument Markings
See the TCDS A696Terry Bowden, formerly TF # 351
[email protected]
Dick,
You can use the search function to find some of this info. Go to this thread for some information that may help you. There is nothing too fancy for a T-Craft regarding this. I understand you may want to see how other people have marked their gauges.
Dick,
Look at the pictures in the post as well as some of the comments. You will see what others have done. Look at Joel Severinhaus' photo of his instrument panel You can also obtain the TCDC under the Technical section of this website, Taylorcraft.org
Go to taylorcraft.org, click Technical Resources, under Contents, go down six selections to TCDS and you will find what you need, A-696. Try this link to get to that page: http://taylorcraft.org/resources.html#Type Certificate Data Sheets (TCDS)Last edited by M Towsley; 12-17-2010, 13:08.Cheers,
