My 1946 BC-12D still has its original fuel transfer valves for the wing tanks and they have recently started sweating fuel residue and really don't hold the fuel back even when in the off position. I have them out now and in researching these i find that the culprit causing the trouble is the rubber o-ring that seals the shaft internally. I need to find a source for this o-ring as they are rather thick and tapered on the side that faces the handle...any thoughts or help in this way would be greatly appreciated as i want to get her flying again...many thanks
Jeff Weldon
slowbird@earthlink.com
Jeff Weldon
