I've finally got all the ribs repaired and coated along with the compression spars, and put them both on the spars loosely. Next up, I tackled the other assorted hardware, trying to place where it goes on the spars and what it does, much less how it attaches.
Given all these things came completely disassembled, I'm making decent headway for starting with no knowledge and twelve boxes of parts. But now I need help again, please?
1. about half my drag/antidrag wires look like steel, and about half are slightly thicker and shinier. Intuition suggests that some of these must be drag wires, the other half anti-drag wires, but which are which? Or did half of them simply get replaced with a different wire and it makes no difference?
2. Am I supposed to have those strange cone-shaped nuts at each end of each wire as well as the tiny regular-looking nuts? Some have both, some have just one, some have neither. I'm guessing that the wierd nnuts - somewhere between flanged and cone shaped - are involved in anchoring the wires in the end of the compression struts...
3. How do you clean all the paint out of the threads without damaging them? Paint stripper is great at removing most of the paint, but it's not coming out of the threads.
4. The tie rods for the wing strut fitting (if part numbers are same between 41 BL12-65 and the L-2 blueprints, it's A-844, goes between D-A80 & D-A81) are bent, and I think one is cracked. Checking the parts source thread lead to a whole lot of talk about the struts, and not much about their fittings. Where do I get replacements?
5. The holes drilled in the shiny new spars are about 1/4 inch off - outboard - from the rear spar butt fitting. Checking with my IA, he said "file about a quarter inch off the butt of the spar, then, and make sure to varnish it." I just wanted to check and see if this is normal, or a DEAR LORD NO sort of thing, because I really am loathe to start taking wood off my spars without multiple people who know what they're doing saying it's okay.
At least I know that I don't know the answers - please help me!
