bc12 up to o-235?
  • bc12 up to o-235?
    i was wondering if anyone out there knew of an stc to put an o-235 in a bc-12. i have a wonderful project i just bought and it comes with an o-235, i figuered i might have a chance if i had the harer stc, then it is a f19 equivolent but i wouldnt know where to go from there. thanx
    josh.
    Re: bc12 up to o-235?
    or does any one konw anything about the stc to make f-19's into f-21's ?
      There is no STC it is the same Type Certificate, just do it. Necessary changes are on the TC.
        Been there done that. Actually took a perfect 47 BC12D fuselage and used it to replace a destoyed '81 F-21 fuselage. Did it on a 337 along with TC data, Gilberti STC(Harer now), and a FAA guy that actually gave a crap about his job about 10 years ago.
          thanks guys .
            Forrest , The F-21 is a different TC than the BC-12D , would the data be interchangeable between the two ? It sure would make a nice combination .
              I was refering to the F-19 change to other F ships; THAT is the same TC...... 1A9 ; actually the first 1A9 was the Model 19 just 19 not F-19.
              The BC12D TC 696 evolved into the Model l9 .
