Need Shinn Axles
  • Need Shinn Axles
    I am looking for a pair of axles for my 1939 BL-65, anybody have a set for sale?
    Re: Need Shinn Axles
    Are you scratch building new gear? How do you plan on installing them?
      We may have them here, but they are welded in.....what is wrong with yours?
        Axles
        I need a set of tapered axles, anybody know where I can get a set?
          I have a couple of sets. They are NOT perfect, but I can shoot a pic your way when I get home tonight and let you make the determination. They're NOS and have been stored a long time.
            I have the landing gear but someone has cut the end of the axles off in the attempt to convert it to a cleveland brake setup. I have all the original shinn brakes and parts, and I have already removed the existing axles. I do not know how the other Taylorcraft axles are held in place but on my 1939 BL-65 they were held on by one bolt, they were not welded.
              AT last a revelation..... real old landing gear, give me the dia. of the inboard part of that axle , back then they were swaged to form the taper, you could have a machine shop turn two new ones. let us check first for axles for you.
                Never heard of that on a "B" model. And I have even had some "A" gear at the shop. I assume the axle would be identical to an L-2 axle then? I should have some extra ones of those.
                  I am willing to bet his was modified..... He called today. I am looking , he is to measure what he needs , perhaps the D axle will work. He is in Hawaii and an A&P go direct to him and see what you can do, thanks
