I put on some new brake linings today. HUGE improvement, even better than when I first got the plane. I still have some replacement shoes on backorder, who knows when they will show up???. Mine are quite pitted from corrosion but I was able to measure the thickness at .90" Maybe that is what they are supposed to be, don't know. Looks to me like the linings are shot when they loose just about .030 - .040" Took a while to figure out how to properly countersink the rivets, and I didn't like the ones that Sky-bound sent with the linings. They seemed a bit too long. Oh well it's all together and working fine now. There were some issues trying to align the shoes with the lining. Can I remove the washer behind the inner bearing to allow the wheel to move inward some more? Should I put a spacer between the backing plate and the axle to move the brake assembly further out-?? Now that I have cleaned all the parts and got a really good look at the system I plan on ordering more parts as spares like a few extra return springs, and the little figure eight locking wires for the adjuster nuts. I also need axle nuts. I have some alum. octagonal nut/mount for the wheel-pants, and the holes for the cotter pin don't line up that good. FYI I didn't adjust the brake cable at all, no need to. Simply replacing the linings, even with the rest of the system worn/rusted heavily, I doubled my breaking ability. No problem locking them up on pavement even with my 8.50 tires. Well worth the $50 spent on new parts!!
Jason
N43643
Jason
N43643
