Engine Change
  • Engine Change
    Replacing my tired A65 with one not so tired. I'm not able to find new Lord Mounts for the installation. ANy sources. 46 BC12D
    L Fries
    N96718
    TF#110
    Re: Engine Change
    Howdy,
    Try Aircraft Spruce, Wicks or wag Aero. They should have what you need.
    Best Regards
    paul patterson
    Edmond, Ok
    N39203 Model 19 class of '45
    TF#509 EAA#720630
      Re: Engine Change
      Lloyd:
      Lord mounts? Does you Cont not require conical rubber mounts?
        Re: Engine Change
        I tried Aircraft Spruce and they want a part no. Heck I'm looking for a part no. to no avail. My old taylorcraft parts list indicates I need 8 Cone Rubber Shock Mounts part no. 22387. I have tried wag aero and univair but they have no listing for taylorcrafts. There is a parts place at Fresno Chandler which probably has what I need but I have been told that they have WWII stock and that the rubber is now hard.
        Robert, when I look at the shock mounts I see round rubber and nothing else.
        Two IA's will be leading the change but I'm trying to round up all the parts before we go t work.
        L Fries
        N96718
        TF#110
          Re: Engine Change
          Just order Con't mounts about $10.00 Wag-areo got them
          There everywhere.
          Robbie
          TF#832
          N44338
          "46" BC12D
          Fond du lac WI
            Re: Engine Change
            Continental P/N 22387 for A-65 (Engine Mount Bushings) 8 required. About
            $1.40 each. Aircraft Spruce Cat. was the source for these numbers...not the most recent catalog, but the P/N is good. Dick
            Dick Smith N5207M TF#159
              Re: Engine Change
              I've e mailed Aircraft Spruce with the part No. Didn't realize the part no. in the Taylorcraft Catalog I had might be the no. Thnks To All
              L Fries
              N96718
              TF#110
                Re: Engine Change
                They cost $1.79 each now and since I live in California they add the
                sales tax.
                Thanks for all the help.
                L Fries
                N96718
                TF#110
