Re: Good brakes
There is something wrong I used an 3-4 bolts and they threaded into the holes on the gear groves print uses an 4 bolts and nuts so he must have drilled the holes in the gear to fit the bolts.this was a change from when he and i talked and i did my brakes.The mounting flange is thin and drilling the holes will make it thinner.Also Tim has one more print that I don't have.Looked at Garys 337 and he used AN 3 bolts also.I think Robbie and talked about this and he used the wrong size on the drawings.
