Spar Dimensions
  • Spar Dimensions
    Does anyone have the exact dimensions for the BC12? I need to order spar stock for both wings and the two ailerons. My original spars seem to be 1/32th beyond standard (or common) sizes (21/32 and 25/32). If anyone has drawings I'd love to get a copy.
    Re: Spar Dimensions
    Hi Tom,
    I don't think that you will ever find drawings.
    When I made my spars for my bc12d I measured my spars and also an F21 spar.
    After measuring and pondering I ordered these pieces;
    4-7/16" x 5/8" x 196" + 1/32"/ -0" rear
    5-15/16" x 3/4" x 196" + 1/32"/ -0" front
    That was in 1992 finished it in '98 and been flying it since 1998.
    I can't find my notes but I am sure that all I did was measure my old aileron spar and order another piece to match.
      Re: Spar Dimensions
      Can't help you with the main spar drawings, but when I remanufactured my aileron spars on my BC12D (note the "D"), I used my old ones as pattern and compared them to the L2B drawing D-A8202, which states (to the best of my eyesight):
      Length: 192 and 7/8 +/- 1/16
      Height: 4 and 3/8 +1/32 -0
      Thickness: 5/8 + 1/32 -0
      Further, drawing D-A8251 describes the bevel (slope) of the upper aileron spar edge as 1/16 across the spar width, and the lower being 1/32
      It does beg the question how in the USA owners are expected to repair broken items if either:
      a) new parts are not available from the TC holder or suitable FAA-PMA source, or
      b) drawings are not available from the TC holder.
      How does the FAA expect owners to comply with current FAA regulations?
      Last edited by Robert Lees; 10-12-2014, 14:05. Reason: to clarify BC12D. Dave, your post now back to original.
        Re: Spar Dimensions
        The current motto is "Nothing happens until something happens." That may be interpreted as; We are not trying to do prevention style safety, but rather we will hammer anyone that appears to have transgressed if we should find anything suspicious during an investigation.
        So it is more like putting an ambulance at the bottom of the cliff instead of a guard rail at the top.
        Y'all be careful out there.
          Re: Spar Dimensions
          Here is a snippit from AC43.13-1B chapter 1;
          1-41. SPAR REPLACEMENT. Replacement
          of spars is a major repair. Spars may be
          replaced by new parts made by the manufacturer
          or the holder of a Parts Manufacturer Approval
          (PMA) for that part. Owner-produced
          spars may be installed providing they are made
          from a manufacturer-approved drawing. Also,
          a spar may be made by reference to an existing
          spar providing sufficient evidence is presented
          to verify that the existing spar is an original
          part, and that all materials and dimensions can
          be determined.
          The dimensions and type of
          wood used are critical to the structural strength
          of the aircraft. Care should be taken that any
          replacement spars accurately match the manufacturer’s
          original design.
          Seems to me that you do not need a drawing and have no issues replacing a spar by duplication.
            Re: Spar Dimensions
            Drude said it perfectly. It's not a huge deal....quit trying to make it one. There's provisions set in place already, and have been for many many years, to take care of this. It takes some knowledge of the FAR's (which any mechanic should have) and a bit of "reverse" engineering. It would be great if we could access all these "drawings" that we're supposed to be able to, but that's not going to happen anytime soon. Maybe a table of dimensions of this sort could be placed in a "sticky" on the site???
              Re: Spar Dimensions
              Thanks guys! All I needed was confirmation of dimensions; I have the original spars in reasonably good condition for a pattern.
              New PMA'd spars are available from Wag Aero, but I would prefer Sitka Spruce and they only offer Douglas Fir. And before anybody jumps on the 'cost' bandwagon, I think the price from Wag Aero is very reasonable considering the paperwork required to get the PMA approval. My only desire is to use spruce, and as pointed out in on of the posts, it's not that difficult to comply with the FAA - you just have to be patient and understand the rules.
                Re: Spar Dimensions
                I'll show my ignorance on the subject by asking:
                When I dismantle my wings for rebuild, how do I determine if the spars are indeed original?
                Mike Wood
                Montgomery, TX
                '46 BC12D
                N44085 #9885
                  Re: Spar Dimensions
                  You should find a little aluminium data plate with the serial number (4 digits) nailed somewhere (the serial number may well not correspond to that of the fuselage).
                  Also (at least on the spars I've seen) there is an inked inspection stamp about 2 inches square under the varnish.
                    Re: Spar Dimensions
                    Hi Mike,
                    Well...
                    What Rob said plus your aircraft records should indicate a change or replacement.
                    BTW I don't think that all the spars have serial number plates.
                      Re: Spar Dimensions
                      Mine didn't have the serial number plate either...but they were signed in pencil, under the varnish, by 2 guys from Taylorcraft on June 9, 1946....and a friend of mine that was working at Taylorcraft at the time my plane was made, knew them both!
