What prop works will with a 85 hp. with a 0-200 crank and rods and pistons
  • What prop works will with a 85 hp. with a 0-200 crank and rods and pistons
    trying to buy the right prop?
    Re: What prop works will with a 85 hp. with a 0-200 crank and rods and pistons
    If I understand the STC right the prop stays the same as when it was a stock C85. So on my stock C85 i have a Sensenich 72/40 metal prop that works grate static rpm's 2350/2400 red line 2650 cruse at 2400 no wind about 100 mph with 26 in BUSH WHEELS. One person full fuel climbing easy 1200 ft per min. same person on take off flying in 100 ft, that is 190 lb person and 24 gl of fuel. I took off Mc 74/43 this works much better.
      McCauley 1A9075/38 is a good climb prop. Or you can use the 1B, but I like long props and the associated climb. Tim
