Installing new struts from Wag Aero...the rear struts are a pain to get on!
The front struts were easy however with the rear struts attached at the outboard end the natural no pressure alignment of the inboard end falls several inches aft of the fuselage bracket. I did get them installed by connecting inboard at the fuselage first and them forcing the outboard end into the wing fitting - with lots of cussing, a punch for alignment, and a rubber mallet!
I'm trying to determine if this is the normal fit or if Wag Aero sent me some bad struts??? The part numbers on the struts do say they are applicable to the "B" model TCraft...
I'm worried about too much pressure/binding on the rear wooden spar because of the misalignment. Whats normal?
Thanks, Doug
713-206-3160
Thanks, Doug
713-206-3160
