My fuselage is very close to being ready to cover. I just have to fabricate and install a com antenna mount and ELT antenna mount. Anyone have any suggestions for the proper size of groundplates and ideal locations, or pictures of their mounts? I assume the groundplate should be grounded to aircraft ground? The com antenna that came with the airplane is a stainless steel bent whip. It does not have a BNC connector on the bottom, just a threaded end to the stainless steel antenna rod?? Should I buy a new antenna?
Any tips or suggestions welcome. I won't be purchasing a panel mount radio until the airplane has been test flown.
