What would be the most cost effective and easiest oil filter adapter kit to install on the 0-235 L2C engine? Thanks for any input.
Oil Filter Adapter
Re: Oil Filter Adapter
I have seen two types one mounts to the accessory case if you have room.The other is made by Air Wolf and it is a remote mount that the filter will bolt any were and use hoses to the engine.I don't have a clue as to the cost.1940 BLT/BC65 N26658 SER#2000
Which one? there are 3 or 4 makers of the adapters and they are all somewhat different. TimOriginally posted by Bonanza91K View PostThe accessory case adapters won't work since the filter won't fit under the cowl. I know I bought one and tried it on my F21.
JimN29787
