What causes cylinder glazing?
My motor had noticable loss of compression (50lbs) on one cylinder & low on another one (65lbs) so I removed the offending cylinders yest to check out problem. When pulling cylinder I noted orentiation of rings was way off. On both cylinders the rings (3 ring pistons) had spun & were in very close alignment, both were glazed but one was far worse, on it the oil ring had spun to the bottom.
This is a 30 hr A-65 motor with very low total hrs. It had new rings & bearings when I rebuilt it & I did the vent & jet mod & spin the motor 2500rpm on take-off & cruise about 2400. It is a great performing motor.
So what can cause glazing?
Improper break-in oil?
Some-one suggested not running it hard enough on break-in?
One thing I just thought of now is when it was assembled & the plane was flown it was getting on in the fall, maybe I didn't get enough heat in it? I ran it during past winter on ice fishing trips & such. The oil intake was closed completely & the cyl cooling openings were partially closed off. The motor ran about 160-170 on oil temp, maybe that wasn't hot enough??
Suggestions?
Suggestions?
