Repainted L-2b
Re: Repainted L-2b
NICE! I agree on the lots of work.Taylorcraft Foundation, Inc
[email protected]
Re: Repainted L-2b
Originally posted by Ed O'Brien View PostLovely. I got one just like it. Let's go find an artillery unit and do some spotting! Boom me!
With regards; ED OBRIENTom Peters
1943 L2-B N616TP
Retired Postal Worker/Vietnam Vet
Re: Repainted L-2b
Dick:
Where did you get your information on my plane. I have been trying to find a data base I could tap into. Since I did not have specific data I used other L2 as a reference.
My plane is registered as a DCO-65 with gross weight of 1300 lbs. This would make it an L2-B since the L2-A has a 1200 lb gross.Tom Peters
1943 L2-B N616TP
Re: Repainted L-2b
Tom, I have been collecting data for close to thirty years. Your ship is a DCO-65 with a 1300 pound gross. All L-2s with a serial number from 4200 to 5165 had agross of 1300 pounds, Tandems with a serial number between 4000 and 4199 had gross weights if 1250,Only the gliders had agross weight of 1200 pounds, The L-2M sn 5166-5199 and 6253-6318 had a gross of 1325.Your serial number told me that your ship was ordered as an O-57A. L-2B s started at 4576. DickTF #10
Re: Repainted L-2b
Tom,
Follow the lonk to the FAA website and you can view the TCDS for the DCO-65.
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/78675250e14ce0af86256d36006571f2/$FILE/a-746.pdf
There you will see the DCO-65, L-2A and L-2B were all 1300 pound gross weight. The L-2M is 1325. There are other variations and you can read about them.Ron Greene
TF#360
Re: Repainted L-2b
I have attached a file that gives the relationshio betweeen aircraft and Army serial numbers.
I will leave it to Dick to explain how he came up with yours as I do not know your Taylorcraft serial number.
I suggest you buy the L-2 Blueprints, if you do not want to buy the blueprints you can view them on the taylorcraft.org website.
The 4 CD set is available for $25.00 where $20.00 will go to the Taylorcraft Foundation and $5.00 will be used to cover shipping and material costs.
A new section has been added to the L-2 CD's thanks to Claude Underwood, it includes a compilation by Claude Underwood of L-2 history, all L-2 Army Technical Manuals including, Erection and Maintenance Manual, Airplane Parts Catalog, Pilots Flight Operating Instructions, and Structural Repair Instructions, also has WWII history, AAC Technical Orders and more. I would like to thank Claude for providing all this information. This is only available on the CD set and not online.
Send check or money order to:
Ron Greene
40336 Calle Medusa
Temecula, CA 92591Attached FilesLast edited by Ron Greene; 08-17-2008, 12:19. Reason: removed the sentece fron a previous post about batteries and generatorsRon Greene
TF#360
Re: Repainted L-2b
Tom,
Go to the National Air and Space Archives Division link below and you can request the Army Air Corps History card for your aircraft.
Go to FAA.GOV to Request Copies of Aircraft Records at this link
The Aircraft Registration Branch maintains registration records on individual aircraft and serves as a repository for airworthiness documents received from FAA field offices. This will give you all the 337's and all the registration info since it left the AAC.Ron Greene
TF#360
Re: Repainted L-2b
Originally posted by Ron Greene View PostI have attached a file that gives the relationshio betweeen aircraft and Army serial numbers.
Ron Greene
40336 Calle Medusa
Temecula, CA 92591
Larry"I'm from the FAA and we're not happy, until your not happy."
