Tools
  • Tools
    DRILL PRESS: A tall upright machine useful for
    suddenly snatching flat metal bar stock out of your
    hands so that it smacks you in the chest and flings
    your beer across the room, splattering it against that
    freshly-stained heirloom piece you were drying.
    WIRE WHEEL: Cleans paint off bolts and then throws
    them somewhere under the workbench with the speed of
    light. Also removes fingerprints and hard-earned
    guitar calluses from fingers in about the time it
    takes you to say, "Yeou sh$t...."
    ELECTRIC HAND DRILL: Normally used for spinning pop
    rivets in their holes until you die of old age.
    SKIL SAW: A portable cutting tool used to make studs
    too short.
    PLIERS: Used to round off bolt heads. Sometimes used
    in the creation of blood-blisters. The most often tool
    used by all women.
    BELT SANDER: An electric sanding tool commonly used to
    convert minor touch-up jobs into major refinishing
    jobs.
    HACKSAW: One of a family of cutting tools built on the
    Ouija board principle. It transforms human energy into
    a crooked, unpredictable motion, and the more you
    attempt to influence its course, the more dismal your
    future becomes.
    VISE-GRIPS: Generally used after pliers to completely
    If nothing else is available, they can also be used to
    transfer intense welding heat to the palm of your
    hand.
    WELDING GLOVES: Heavy duty leather gloves used to
    prolong the conduction of intense welding heat to the
    palm of your hand.
    OXYACETYLENE TORCH: Used almost entirely for lighting
    various flammable objects in your shop on fire. Also
    handy for igniting the grease inside the wheel hub you
    want the bearing race out of.
    WHITWORTH SOCKETS: Once used for working on older
    British cars and motorcycles, they are now used mainly
    for impersonating that 9/16 or ½ socket you've been
    searching for the last 45 minutes.
    TABLE SAW: A large stationary power tool commonly used
    to launch wood projectiles for testing wall integrity.
    HYDRAULIC FLOOR JACK: Used for lowering an automobile
    to the ground after you have installed your new brake
    shoes, trapping the jack handle firmly under the
    bumper.
    EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an
    automobile upward off of a trapped hydraulic jack
    handle.
    TWEEZERS: A tool for removing wood splinters and wire
    wheel wires.
    E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times
    harder than any known drill bit that snaps neatly off
    in bolt holes thereby ending any possible future use.
    RADIAL ARM SAW: A large stationary power saw primarily
    used by most shops to scare neophytes into choosing
    another line of work.
    TWO-TON ENGINE HOIST: A tool for testing the maximum
    tensile strength of everything you forgot to
    disconnect.
    CR AFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry
    bar that inexplicably has an accurately machined
    screwdriver tip on the end opposite the handle.
    AVIATION METAL SNIPS: See hacksaw.
    TROUBLE LIGHT: The home mechanic's own tanning booth.
    Sometimes called a drop light, it is a good source of
    vitamin D, "the sunshine vitamin," which is not
    otherwise found under cars at night. Health benefits
    aside, its main purpose is to consume 40-watt light
    bulbs at about the same rate that 105mm howitzer
    shells might be used during, say, the first few hours
    of the Battle of the Bulge. More often dark than
    light, its name is somewhat misleading.
    PHILLIPS SCREWDRIVER: Normally used to stab the vacuum
    seals under lids and for opening old-style
    paper-and-tin oil cans and splashing oil on your
    shirt; but can also be used, as the name implies, to
    strip out Phillips screw heads. Women excel at using
    this tool.
    STRAIGHT SCREWDRIVER: A tool for opening paint cans.
    Sometimes used to convert common slotted screws into
    non-removable screws.
    AIR COMPRESSOR: A machine that takes energy produced
    in a coal-burning power plant 200 miles away and
    transforms it into compressed air that travels by hose
    to a Chicago Pneumatic impact wrench that grips rusty
    bolts which were last over tightened 30 years ago by
    someone at Ford, and instantly rounds off their heads.
    Also used to quickly snap off lug nuts.
    PRY BAR: A tool used to crumple the metal surrounding
    that clip or bracket you needed to remove in order to
    replace a 50 cent part.
    HOSE CUTTER: A tool used to make hoses too short.
    HAMMER: Originally employed as a weapon of war, the
    hammer nowadays is used as a kind of divining rod to
    locate the most expensive parts adjacent the object we
    are trying to hit. Women primarily use it to make
    gaping holes in walls when hanging pictures.
    MECHANIC'S KNIFE: Used to open and slice through the
    contents of cardboard cartons delivered to your front
    door; works particularly well on contents such as
    seats, vinyl records, liquids in plastic bottles,
    collector magazines, refund checks, and rubber or
    plastic parts. Especially useful for slicing work
    clothes, but only while in use.
    DAMMIT TOOL: Any handy tool that you grab and throw
    across the garage while yelling "DAMMIT" at the top of
    your lungs. It is also, most often, the next tool that
    you will need.
    (;f
    Bob Ollerton
    Re: Tools
    I lost my list thank you for posting, I use many of these items to teach new mechanics the real life they will lead. I'M BACK! POSTED NEWSLETTER TOO here comes snow again!!! thanks Bob I needed the grin
