BC12D New Exhaust and Heat Shroud.
  • BC12D New Exhaust and Heat Shroud.
    Time to replace the exhaust and heat shroud. Looking at buying from Univar. Is anyone using their system. How is the fit and finish. Are you happy with the results? Thanks. Tim.
    Re: BC12D New Exhaust and Heat Shroud.
    I have spoken to several owners who switched to the luscombe exhaust after problems with the t-craft system. They all like it much better. I was planning on doing this had I kept mine. JC
      Tim as I just did the engine on my plane and chose to do the luscombe change there are photos on the blog look for C85 up grade now the exhaust system i bought from Doug Coombs at the luscombe foundation becouse his are made out of a heavier aluminum cost $1100.00 the only thing that is in the way is the gascolator it needed moved other then that it fits grate and can be maintained at annual with out pulling the engine also terry Bowden has the paper work to make it legal and it sounds grate
