What the H*%L is this?
  • What the H*%L is this?
    I figured somebody on this forum could tell what this thing is, I've owned it for years.
    Vincent
    Re: What the H*%L is this?
    It is a variable resistor. Something very similar is used to "parallel" alternators on twin Cessna's.
      Man that thing is old. Believe the name is rheostat. Was used in school laboratories and test labs. It is a wire-wound resistor that is set up so you can use it as a voltage divider. I suspect the support cylinder is made of ceramic so you can heat it up and not burn it up. Suspect the wire is nichrome--the ones I have seen were. Will light up like a electric stove coil if you get carried away (that is why the wire is black).
      Hook 12 volts across the coil, set the slider to the middle and you get 6 volts, and a warm room, Chuckle.
      Could use it to compare 1 thru 9 volt analog meters ( with a pointer, remember) with a more precise meter when you only have a 10 volt source.
        Yep, a rheostat (variable resistor). Basically a wire wound resistor with a moveable tap-slider. By the marking on the knob my guess would be zero to fifty ohms. Test it with a Ohm meter across the end terminals or hook it to a battery in series with a light bulb. Moving the slider will vary the current making the bulb brighten or dim. Be carefull not to set it for a low resistance with a high capacity battery or as stated - High current - the wire will glow possibly ruining the resistor.
        David
          that's one old wirewound resistor! any interest in selling it? I collect things like this
          DJ Vegh
          www.azchoppercam.com
          www.aerialsphere.com
          Mesa, AZ
            My guess is that it isn't a very high current resistor,the size of the winding tells me it wont last long at anyting above 10 amps or so.Still, its really cool.
            PV
              I had something like that on a crystal radio set and seeing that it was made by zenith I would be inclinded to say it was used for a radio
