Prop hub needed ASAP in Alaska
  • Prop hub needed ASAP in Alaska
    I need to buy or borrow a circ ring for / or a tapered shaft prop hub adapter. I need it tomorrow if I am to make it to the Skwetna craft flyin on Sunday. Thanks,
    Rod 907-382-1289
    Re: Prop hub needed ASAP in Alaska
    Thanks all. I received a couple calls and chased some leads until I discovered I already had a prop hub adapter on an old 65hp engine that I removed from the tcraft over 15 years ago.
    Back in business ...
    Rod
      Yay! See you in Skwentna. We'll all be drooling on your plane!
