Quick Answers to Sport Pilot Questions
Here is a collection of answers to some of the more common Sport Pilot questions received this week at EAA headquarters.
Gross weight = 1,320 pounds (600 kilograms)
Floatplanes = 1,430 (650 kilograms)
Maximum Full Power Speed = 120 knots (138 mph)
Stall Speed = 45 knots (52 mph) · no more dual stall speeds
Fixed Prop - may be ground adjustable
Fixed Gear - amphibians allowed "repositionable" gear
Two- Place - pilot and one passenger
Day VFR
Driver's License Medical Approved - however, if you have received a letter with the word "denied" from FAA, not from your doctor, you must get a one-time special issuance or FAA authorization · even if you have been denied in the past, you can try again for special issuance (medicines have changed, for example) · more on this as EAA continues to analyze the new rule.
Owner Maintenance Approved on ELSAs - no changes - if you are operating an Amateur-Built or Standard category as an LSA, maintenance remains as it was without change.
No Recertification of aircraft required or permitted (this means ultralights are converted to ELSAs; all other aircraft certification and maintenance remain the same).
Rule Effective Date = 9/1/04.
Day VFR
