Is the short engine mount for the c-85 the same engine mount for the a-65?
short engine mount question
Re: short engine mount question
Yes, I believe it is. The later C-90 engines had the "Lord Mount" style and would require an adapter, but I think all the 85's fit an identical mount as the 65.Taylorcraft : Making Better Aviators for 75 Years... and Counting
The C90-14 uses the same mounts as the O-200. The -8 and -12 are the same as the earlier engines. (there was a C85-14, too, but no one has ever seen one, AFAIK...) No adapters necessary for the Lord mounts, but the engine will sit about 3/4" farther forward than one with conical mounts.Originally posted by VictorBravo View PostYes, I believe it is. The later C-90 engines had the "Lord Mount" style and would require an adapter,
