Farm strip
    Re: Farm strip
    I've got 2-1000' strips on the farm. One has a hill with about 350' on top. I'd always be flying by the drop off or fly when I'd start down the hill. I'd vote for for #1. You'll be off in 400'.
    Eric Richardson
    1938 Taylor-Young
    Model BL NC20426
    "Life's great in my '38"
    & Taylorcoupe N2806W
    TF#634 :tup:
      Re: Farm strip
      One thing that I did to help preserve my grass runway, at least I think it helped is I had mine registered with the FAA as a private airport and it is now on the Chicago sectional, it doesn't cost anything and it at least lets people in the area know that it is legitimate at least with the FAA, I also contacted the State of Iowa it is no hassel at all, You can call the FAA Airports division and they will send you a packet of information that you can fill out, if you are interested, it took a couple of months total.
        Re: Farm strip
        There MUST be an ole taildragger pilot around there who can come out and see your options. Until I decided WHICH option, I would tell NO ONE! Once you decide, I'd Mow it, roll it and land on it some. No complaints? keep using it. Personally, I would not get the drones involved until someone complained. If its out the country and your not flying low over someones house, whats the problem? I can tell you that TREES look REAL BIG on a hot day, 2000 ft above MSL if it doesn't want to get out. I've been there and its real scary! JUST made it over the trees! Not very bright! Mr. Pearson is right on! Alot has to do with WHERE you are. Here in Maryland people react to light aircraft as though its the Wright Bros. first flight. Complain about noise alot, (but many own Harleys with little or no mufflers.) and generally pose a bad time. They usually DO NOT want a ride and many are bored and want something to bitch about. JC
          Re: Farm strip
          If the "airport" or "landing field" can be registered with the FAA , do so first and then present to the locals IF they contact you. In Ohio that piece of paper is like gold and then the local zoning can explain to their constituants that the Federal approval overrides their local authority. In Ohio that would be a Class IV operation. ( private too)
            Re: Farm strip
            It took 6 weeks but I finally got a reply from the FAA: they sent a nice note and a link to Form7840-1 "Notice of Landing Area Proposal" It's a single page form with 2 pages of instructions. They say I'm supposed to mark the location of the runway on a quadrangle map...I'm not sure what that means, is "quadrangle" another name for a sectional chart?
            Bob Gustafson
            NC43913
            TF#565
              Re: Farm strip
              A quadrangle map is a USGS topographic map. It is used for hiking and understanding terrain in great detail. I know you can order them from the govt and any good map store or surveyor should have them too.
              They are normally named for a town in the quadrangle.
              Mike Rice
              Aerolearn
              BC12D N95910 Tale Dragon
              TF #855
                Re: Farm strip
                Bob – I can generate a copy of the quadrangle map for the area where your strip is. If you’re interested let me know where it is exactly and I’ll see about doing this.
                If you would rather just order a paper quadrangle map they can be ordered by going to:
                There are also a number of sites where you could access and print from online.
                Blake
                Blake Carlson
                Crookston, MN
                1941 BC12-65
                N47665
                Member #1009
                  Re: Farm strip
                  Thanks, Blake.
                  I ordered two quadrangles from the usgs store link, a regular contour line map from a 1953 survey ($8) and an arial photo map from 2009 ($15). The guy at the local map store (who did not offer to get a quadrangle for me, by the way) said quadrangles were too detailed to be useful to anyone, because they only cover a 8 mile by 10 mile area. Well, hell, that sounds like just what I need...I should have them in hand in about a week.
                  Bob Gustafson
                  NC43913
                  TF#565
