Originally posted by flyguy
View Post
When McCauley says a prop is limited to a certain length for a certain engine, it's because more (or less) length can change the resonance of the system into a range that coincides with the hammers attached. This is why you'll see some prop-engine combinations placarded against operating in a particular RPM range.
Look, for example, at the C75 and C85 combined with the 1A90. The engine is exactly the same except for the carb. Why the different prop lengths? Well, the C75 redline is 300 RPM less, which apparently keeps the longer prop out of the danger zone. Now, look at the 85 vs the 90. Here you're allowed a slightly longer prop on the 90. Why? Well, different crank, cam and RPM range. Now look at the C90 vs the O200. Here we have a different RPM range and different cam and a much shorter prop length.
HTH
