what NEW T-crafts parts do you want to obtain in the next 24 months ?
    Re: what NEW T-crafts parts do you want to obtain in the next 24 months ?
    Dave... I found it. It was a thread titled "replacement parts sources". On 5/22/2008, UNIVAIR posed the same question... perhaps you can go look it up and include the input from that thread also on your list. See below for link to the thread...
    http://vb.taylorcraft.org/showthread...univair&page=2
    p.s. this is a good idea and should really help us identify not only what parts are in demand, but where to go find the ones that are available.
      '46 elevator trim jack screw
        Conversion kit from BC12D to BC12D-4-85. (or Model 19 with a gross weight of 1320 lb)
        OR
        A letter stating the BC12D serial number airframes are similar enough to the -4-85 serial numbers that a conversion is possible using the TCDS. (can’t now because the s/n eligibility listing on the TC).
        BC-L637-19 Baffle assembly – complete 85HP
        2590 Manifold assy. Exhaust – complete 85HP w/starter & gen.
        BL-A689-19 Muff assy. Complete 85HP w/ starter & gen
        B-A693 Shut-off assy. – cabin heater
        628122 Carb. housing assy.
        B-9039-19 Cowl hinge – slim seam – center - 85HP w/ starter & gen
        B-9026-19 Cowl hinge – slip seam – outer – 85HP w/starter & gen
        B-A681-19 Cowl assy. Bottom 85HP – long mount
        B-A679-19L Cowl assy. Top left 85HP – long mount
        B-A679-19R Cowl assy. Top right 85HP – long mount
        B-A679-2 Spark plug enclosure – top cowl
        B-1093L-R Rear cowl assy.
        B12-A118-1 Bracket – rear of bottom cowl – firewall mounted
        797-9 fuel gauge base
        A-306 sealed gas cap
        B-A37-3 Wing tank cap
        B12-312 Ring – wing tank cap airing
        4486 Print for wing tank installation
        B12-9085 Knob – gas shut off
        B12-A62 Rod – gas shutoff control
        B12-9102-1 Throttle control – 85HP w/starter & gen
        0979-1 Control panel deck panel
        0993-1L-R Door assy. Glove compartment
        0896 Instrument panel
        A-A27-1 Control universal – complete assy.
        B-A107 Spring assy. – rudder pedal return
        A-146 Bushing – cable fairleads (round)
        D-A400 Link rod assy. – trim tab
        D-A401 Drive assy. – trim tab
        B12-406 Screw – trim tab actuating
        1829-1 metal – fairing fuselage front at landing gear
        2245-2 stringer support – metal – rear of floor board
        1245L-R Rear “D” window frame
        3244 installation print – rear window frame
        1551-6300 molding – rubber – bottom of windshield
        1132 Fairing – metal – bottom of windshield
        1144-2 strip – metal – top of windshield
        1144-3 strip – metal – side windshield trim
        1148-2 seal – top strip
        1148-3 seal – side strip
        1762-1L-R cable cover – front door posts
        B-76L-R nose piece – butt rib at windshield
        1620-3L window frame – left door
        2570 Spar bushing – 11/16 OD
        A-8089 Nipples – drag wire ends
        B-A809-2L-R front spar strut fitting – 85HP
        B-809-2L-R Rear spar strut fittings – 85HP
        A-A806-1 Front spar butt fitting – 85HP
        D-A8295-R-L Wing leading edge – tip
        2419L-R wing root trim
        B12-A771-1L-R fairing – wing butt to fuselage – wedge shape
        1770-R-L fairing – trim – attaches to fuse over door
          Current tally;
          approximately 127 items to order (oops I counted drap wire nipples as one item so its 127 + items)
          about 109 unique part numbers
          approximately 2 or 3 dozen are available from current sources based on my memory
            How about wing ribs, wing spars, fuselage and some landing gear with stright axles or a conversion kit.
            Bill
              major wing parts; ribs, spars, leading edge transition pieces, wing tip bows. Like Bill I would like landing gear w/ straight axles and or conversion kits.
              TF #1030
                I will need to get new lift struts as per the AD that we have Harry to thank for. BY THE WAY, I just googled up Taylorcraft and read about someone in Florida taking over the Taylorcraft factory. Is this legit, or is it just more of Harry's games? Brie
                  Brie if you have good struts , you do not have to buy new ones. I beleive it is Wag Aero that has the right to rebuild yours and make them sealed and comply for a lot less money. Marv
                  Marvin Post TF 519
                    Originally posted by guns68 View Post
                    spars
                    A planer, table saw, and a drill press- they take a Saturday and a half to make.
                      True, but with a shot bag, set of dollies and hammers, an English wheel etc. I could build (or repair) the rest of the parts as well. At times it's satisfying (or necessary... don't we all know that) to build the parts, but sometimes buying them is the better course of action (for me at least)
                      TF #1030
                        Marv,
                        THAT would be GREAT! Mine seem to be fine, the aircraft was completely disassembled in 1997, and rebuilt, airframe, engine, everything over the next three years. I was going to spend the "big bucks" and have whatever Alaska airframes is called now send me a pair of 4130 struts, but if Wag Aero can rebuild mine, then I can get legal a lot sooner. Brie
                          I just checked with the Wag Aero webstore, and there is no mention of them rebuilding the lift struts for Taylorcraft wings. Brie
                          • #28
                            Brie if it is not Wag Aero it is Univair. It was discussed on this forum. I am not the only one that knows about a company rebuilding them for you. Marv
                            Marvin Post TF 519
                            • #29
                              Wagaero can inspect and seal your struts. Cal there 800 number. George
                              • #30
                                wag-aero 1-800-558-6868 ask for John Armes ext-155.John can fix you up.He is the man to talk to about inspecting and converting original struts.
