Stromberg Carburetor Overview
  • Stromberg Carburetor Overview
    I discovered an informative reference on Stromberg carburetors which I have attached as a pdf file. It was located on the www.luscombe.org web site, which also has quit a bit of additional information pertinent to Taylorcraft owners. The Stromberg carburetor reference addresses several questions brought up in another thread on this forum called "Rough Running At Full Power". I found the references to mixture control relative to altitude of particular interest.
    Does this look like a good reference to those of you with some carburetor experience?
    Blake Carlson
    Crookston, MN
    1941 BC12-65
    N47665
    Member #1009
    Re: Stromberg Carburetor Overview
    Also view:
      I have had a neoprene needle for 22 years and used mogas for probably 20 of them.
      I look up neoprene and find that it has good characteristics with chemicals and I suspect that our fuel hoses are made from neoprene compounds so I am a bit skeptical since this doc says they are dangerous.
        I also have a neoprene needle in my carb...been in there for 29 years and still looks like new.
        Terry Norris of Aircraft Systems in Rockford Illinois gave a seminar at Oshkosh years ago on the Stromberg carb. He stated that the original Stromberg neoprene needles, identified by a hand scribed part number on the needle, was not affected by any type of aviation or auto fuel. After market needles with a stamped or machine scribed p/n would swell and deform after a few years.
        Garry Crookham
        N5112M
        Tulsa
          Later ones probably made in China, Chuckle.
            Originally posted by Garry Crookham View Post
            ...He stated that the original Stromberg neoprene needles, identified by a hand scribed part number on the needle, was not affected by any type of aviation or auto fuel.
            Yes, there seem to be good neoprene needles and bad neoprene needles. Unfortunately, it's not that easy to identify them. I've definitely seen hand marked needles with deteriorated tips.
            New Yoke hub covers
            www.skyportservices.net
              I have a new one still in the packing I want to dig it out and see if it is neopren or Viton ( and then I am going to research the difference in the two).
              My job has been very busy it may take a while to get to it.
                There are no Viton needles. (That would be perfect. I actually looked into having some made, but the tooling is $ and the market is small). The neoprene needle is a steel body with a neoprene tip. The Delrin needle is machined completely from a block of Delrin. It is much lighter, hence the need to add the weight to the float.
                New Yoke hub covers
                  I think the Cessna 120-140 pdf is a little better explanation than the Luscombe site because of its statement " Because of this “auto” feature, the manual mixture is rarely needed until cruising above 10,000 feet." I routinely use it above 7,000 and at 9,000 I usually pick up from 80-150 rpm and reduce my fuel burn rate from 4.2 gal/hr to 3.6-3.8 gal/hr. Those of us who fly around the mountains or the desert south west find it really useful because of the need to fly high for either terrain or cool air.
                  Cheers
                  Jim
