I found a $9.99 Hydrualic jack for the main gear
  • I found a $9.99 Hydrualic jack for the main gear
    I was in Harbor Freight and saw this. Its a 2 ton bottle jack that is 6-1/8" high.
    That will fit under the inboard axle stub on a B Model.
    Was $9.99 and item #96647.
    Most 2 ton jacks are too high, about 7-1/4" as I recall.
    I have been using another 6-1/8" jack for 11 years but found a second use for it in the shop so I wanted another one. Have been looking for a while but this is the first time I have seen them again. I don't see the shorter jacks arouns as often as the 7".
    If you are searching for a way to jack up your T this may be your answer. First verify that 6-1/8" will work for you just to be sure.
