Rudder fitting
  • Rudder fitting
    How is the tail wheel fitting at the bottom of the rudder attached. Is it welded in place?
    Re: Rudder fitting
    I think you are asking about the rudder horn that attaches to the tail wheel with springs, if so then the answer is by 2 - AN3 thru bolts that go thru the horn casting and the rudder spar.
